stlar_admin
Group Riding Hand Signals 101
http://www.ridemyown.com/articles/safety/handsignals.shtml
Motorcycle hand signals are important for all riders to know and understand but especially when riding in a group.
(When riding in a group the signals should be relayed back through the group.)
Start.gifSTART ENGINES
With your right or left arm extended, move your index finger in a circular motion.
Left.gifLEFT TURN
Raise your left arm horizontal with your elbow fully extended.
Right.gifRIGHT TURN
Raise your left arm horizontal with your elbow bent 90 degrees vertically.
HazardLeft.gifHAZARD LEFT
Extend your left arm at a 45 degree angle and point towards the hazard.
HazardRightA.gifHAZARD RIGHT A
Extend your right arm at a 45 degree angle and point towards the hazard.
HazardRightB.gifHAZARD RIGHT B
Extend your left arm upward at a 45 degree angle with your elbow bent to 90 degrees and point towards the hazard over your helmet.
Speed.gifSPEED UP
Raise your left arm up and down with your index finger extended upward.  This indicates the leader wants to speed up.
Slow.gifSLOW DOWN
Extend your left arm at a 45 degree angle and move your hand up and down.
Stop.gifSTOP
Extend your left arm at a 45 degree angle with the palm of your hand facing rearward.
Single.gifSINGLE FILE
Position your left hand over your helmet with your fingers extended upward.  This indicates the leader wants the group in a single file formation. Usually this is done for safety reasons.
Stager.gifSTAGGERED   or  SIDE-BY-SIDE FORMATION
Extend your left arm upward at a 45 degree angle with your index and pinkie finger extended. This indicate that it is safe to return to staggered formation.
Tight.gifTIGHTEN UP
Raise your left arm and repeatedly move up and down in a pulling motion.  This indicates the leader wants the group to close ranks.
Ticked.gifTICKED OFF
Extend your left arm straight out with your elbow bent 90 degrees. Carefully extend your middle finger to clearly demonstrate your dissatisfaction with the other guy. NOTE: It is not recommended you do this when you are alone.
Special thanks to graphics from: Ann Arbor Hog Chapter
This topic is now closed to further replies.
